48295
Passive film formation and passivation
[South Korea]
March 26, 2008
dear all;
My question is about passive film formation on stainless steel. If we
scratch the surface, in how much time will passive film re-form and
what about its thickness?
What if we don't use passivation, rather we do fine grinding and
proper cleaning afterwards. Passive film will form automatically and
if surface was clean, there should not be any difference in its
ability to resist corrosion?
Passivation with citric acid or nitric, will mainly clean the surface
and expose more Cr to be oxidized, but if we manage the cleanliness
by alkaline cleaning and water jetting and make sure about that, what
is ur opinion?
Ihsan Jut
engineer - South Korea
First of two simultaneous responses -- March 28, 2008
It depends a lot on what grade of stainless you're talking about.
Alloys high in Cr are better able to self passivate without a
chemical treatment.
When you scratch, grind, or otherwise damage a stainless passive
layer, you are exposing iron to the environment, and it is this iron
that will be the source of any rust that may develop. Chemical
passivation with citric or nitric acid will remove the iron, leaving
a Cr-enriched surface that forms a better Cr oxide layer. Mere
alkaline or water jet cleaning will remove grease, oil, and dirt,
yes, but not specifically the surface iron.
Second of two simultaneous responses -- March 29, 2008
Ihsan
As you are aware, stainless steel will form a passive surface on its
own. You can accelerate this by heating the metal. However, neither
addresses the removal of free iron from the surface.
If it was as simple as cleaning the surface, anyone could say they do
passivation.
Willie Alexander
- Colorado Springs, CO
May 14, 2008
Ihsan,
It but natural that there is going to a passive fil formation by the
Cr in the steel, but it also tru that you will be exposing Fe to the
atmosphere in which the free energy of FeO is higher that any of
carbides of cr with fe so there will be corrosion and that is why we
have to do the passivation treatment to mask the surface with Cr
oxides, through passivation solution and clean the surface
also.
This is just an opinion.
Budhisagar Naik
- India
May 15, 2008
This is a recurring subject. Yes, SS naturally forms the passive
layer by simply exposing it to air at room conditions. But
passivation process besides cleaning out iron impurities from the
manufacturin ops. also depletes the iron from the alloy to several
angstrom deep down the surface. This theoretically creates a better
an resilent passive layer as the surface is enriched with chromium.
wish you good luck.
Manuel Sández
University of Sonora - Hermosillo, Sonora, Mexico
