48252
White hazy finish after descaling Titanium
[Canada]
March 21, 2008
Hello,
I am responsible for the cleaning and descaling of Titanium Heat
Treated (950 Deg F for 1 hour) parts. I am currently using an
alkaline cleaner with a dechlorinated and DI water rinse prior to
descaling. The same cleaning procedure is used prior to the heat
treating process.
These parts are being descaled in a 20 - 25% Nitric acid/ 1.5%
Hydrofluoric acid solution for a period of 1 - 5 min's, then rinsed
in a dechlorinated city water bath (Continuos overflow)and then a
final dechlorinated DI water spray rinse.
Sometimes we are seeing a white hazy blotchy finish and other times a
uniform nice clean looking finish. The descaling purpose is to remove
any free iron left on the parts due to the welding and heat treating
process. I checked the white, hazy, blotchy, areas with a Kozlow free
iron tester and they are free of iron.
I am new to this type of process (Descaling & Passivation) and I
want to make sure things are being done right.
Any suggestions or comments would be greatly appreciated.
Thank you !
Michael Hall
Aerospace technician - Metal finishing - Ottawa, Ontario,
Canada
March 25, 2008
Michael,
the cause of such foggy spots is due to slight damages from previous
processes (or some iron remaining on the surface). If surface of
titanium parts is uniform, the nitric + HF solution produce uniform
clean surface. However if any cracks or uneven alloy structure, or
else take place, then there is not enough of nitric in local areas
(nitric acid works as passivator), and hydrogen starts to damage the
surface.
Our titanium etching gel or liquid electrolyte do not produce white
or foggy areas on titanium surface, even if initial surface is not
perfect.
March 26, 2008
If I remember correctly, the nitric - HF ratio has to be more than
14:1, which if your tank goes low on the Nitric or high on the HF,
then it will etch. As Anna said, if it is a rolled )rough) surface it
can be attacked.
- FL
March 31, 2008
Thank you for your replies.
I try to maintain a ratio of at least 16:1 Nitric/Hf. However when I
am making additions of Hf to the bath, I am doing so because the
descaling process is taking longer than usual due to the Hf being
consumed (Correct me if I'm wrong). Or is it because the dissolved
titanium in the bath is slowing the descaling process ? I make a new
bath when the dissolved titanium reaches 10g/L.
I do not add Nitric when adding Hf because my concentration level for
Nitric is pretty consistent at 20 - 25%.
Should I be adding Nitric, when adding Hf ?
Sincerely,
Michael Hall
Metal Finishing - Ottawa, Ontario, Canada
April 1, 2008
Adding nitric would not be required as you add HF. I normally
started with the weakest bath allowed by the OEM's and gradually
increased the HF as it was used until I got to the max allowed. To
keep the nitric-HF ratio proper, I had to add more nitric from time
to time.
The problem is several fold. A bit of the HF is being used (tied up
as a complex molecule) but you should be titrating for free flouride
and not total flouride. The etch of the Ti is reduced by the
formation of the complex IE: the more product that you form, the
slower the reaction, regardless of concentration of the HF. There are
equations for working this out, but it is a chapter in the chemistry
book. Adding HF to the limit just allows you to get a bit more time
out of the solution.
- FL
May 10, 2008
I do not kow whether this comment will help but I use hydrogen
peroxide to remove titanium oxide (and nitride) from titanium. The
concentration can vary greatly. I control the pH to 7 - 9 using
pyrophosphate as a pH buffer. In my case I have glass and other
materials destroyed by nitric and hydrofluoric acids but even if I
did not I would still prefer hydrogen peroxide. Dissolution of the
oxide takes 1 - 24 hours. You can shorten the immersion time by
heating and by raising the concentration of hydrogen peroxide. I
usually leave my parts in the solution overnight cold. This process
does nothing to brighten a dull surface; the titanium is not attacked
at all.
Nick Clatworthy
- Whitstable, Kent, UK
