48036
Sludge in phosphating line (difference
between of galvanized sheet and normal sheet) [Iran]
March 4, 2008
Dear sir or madam,
I want to compare sludge and waste in phosphate tank. when we use
galvanize sheet and normal sheet in phoshating line before painting
in automotive line .
In Some text says:
1- Sludge for normal sheet 5-10 mg/Lit
2- Sludge for galvanized sheet 0.5mg/Lit
3- Sludge for aluminium 10-30 mg/Lit
Could you please guide me this number is routine and usual or
not?
Best regards
Nader Bayrami Tarouni
- Tehran, Iran
March 4, 2008
Can you please put this in context, Nader, because we don't know
where you're going. Do you already phosphatize galvanized steel but
not plain steel? Or is it vice versa? Or you are just planning to
build a line? Or you already phosphatize and your numbers disagree
with the literature? Thanks.
finishing.com
Brick, NJ
