48035
Surface Marks on Aluminium Extrusion after
ECM [Malaysia]
March 3, 2008
Hi my name is Mike Walker, I work for an automotive supplier in
Kuala Lumpur Malaysia. I am enquiring about a problem that one of my
suppliers is having with his Electro Chemical Deburring
Process.
We are seeing a white patch within the finished bore of an extruded
aluminium part. The patch is rough to the touch as if there is an
acid etch reaction.
ECM is our only real option for deburring as the daily volume of
components required is 2,000 pieces. The process has been running for
more than 2 years with no problems until recently, can you suggest
possible causes.
Mike Walker
Project Manager, Automotive - Kuala Lumpur, Malaysia
