48027
Recovering scrap gold and platinum plated
tweezers [California]
March 1, 2008
I currently have a continuous supply of scrap tweezers that were
plated with 50 microinches of gold and 80 microinches of platinum.
Would it be worth my while to hold on to these and try stripping them
later or am I wasting my time?
Gary Chien
hobbyist - San Francisco, CA, USA
March 4, 2008
If the whole tweezer is plated, that's a fair amount of gold and
platinum. If it's only a selected area it might be worthwhile if you
can cut that section off. Try to locate a refiner and see what they
say about their interest in this.
finishing.com
Brick, NJ
March 5, 2008
The tweezers are plated as follows: 3/4 of the tweezer is plated
with gold and the rest including the tip is platinum. How can I
calculate how much I would be able to get from say a refiner and how
can I locate one?
Gary Chien
March 5, 2008
You know the thickness, so you must estimate the area to get the
volume of precious metal. Multiply by the density and you have the
weight. Multiply by the going price for the precious metals and you
know what the recovered metal is worth is if they could get 100
percent of it. That gives you a upper limit number which you will
obviously not be able to reach or exceed. Then you can talk to
refineries and ask them to do a sample and negotiate a fair price. If
you do a search for 'precious metal refinery' you'll see a lot of
them.
 Ted Mooney, P.E. finishing.com Brick, NJ
April 14, 2008
Thank you for your responses. Just one last question. Should I cut
and seperate the tweezers in order to separate the gold from the
platinum or will the refiner be able to recover both metals with no
problems and with no extra fees?
Gary Chien
- SAN FRANCISCO, CA, USA
April 14, 2008
Hi, Gary. If cutting the tweezers ought to be done, you have to do
it yourself or expect to pay for it. But, sorry, I can't say whether
the refinery can recover the metals easier if you cut them along the
line between gold and platinum. I tend to doubt it though, as I
expect they will try to recover both gold and platinum from both
areas anyway. Good luck.
