48002
Titanium Racks for small parts
February 28, 2008
I need to know how many parts I can run in (one time) the
anodizing tank Type I; the size of the tank is 24x24x36 deep inches;
I have enough rectifier capacity; I need kind of rack to run more
parts 2x1x1/2 inches, with hole each one
Fausto Cabrera
Fausto Cabrera
Plating Employes - Santiago, Dominican Republic
February 29, 2008
A box or a fan type rack will work about the same.
The box can be of a width and depth that is best your tank,
You can run 1 large fan type or possibly 2 smaller ones.
The central spine on the fan or the 2 on the box rack must be able to
carry what ever the current is that you end up with based on the
number of parts times the area. There are two voltages possible for
Type I and the higher one will take nearly double the amperage that
the lower voltage will (initially).
I would strongly recommend that you send a picture of the part with
precise dimentions to two or three reputable anodize rack
manufacturers. Include the liquid depth that you plan to run and let
them price racks for you. Compare their recommendations and take your
pick.
Do not get greedy and try to get racks too close to the sides and the
bottom of the tank, or the liquid level or you will not anodize
properly and increase the probability of arcing a rack/part out.
