(Cycles thru suppliers)
  48001
Anodizing Titanium
February 29, 2008
I am interested in what electrolyte is used to anodize titanium for subsequent adhesive bonding.
Paul D. Stransky, CEF
retired - N. Grosvenordale, Connecticut
March 1, 2008
Depends what you want out of the bond. If it is structural then you may like to look at an alkaline system such as AMS2488 [link is to spec at TechStreet]. If it is simply to get things to adhere you could consider sulphuric acid anodising, gives a very thin blue coating, nanometers thick.
You may consider other methods ass well, such as wet abrasive blasting the surface or alkaline peroxide oxidation. The wet blast will not give a durable bond for hot or humid conditions, nor will the sulphuric acid anodising. If bonding for operations in hot and/or humid conditions you do need either alkaline anodising or alkaline peroxide oxidation.
Brian Terry
March 18, 2008
I have had success using a fluoride phosphate and using a chemfilm coating to improve adhesion for aerospace paint on titanium.
Jim Dedmon
- Ventura, California
March 13, 2009
I am working in a scientific Iraqi center, becoming interested in surface engineering especially in anodising process, so my question is: to anodize pure titanium ,what is the effective procedures used? how can we decide that are the optimum requirements to pre-anodising treatment.thanks
Dr.shrok abdullah
ministry of science and technology - baghdad, Iraq
March , 2009
Hi, Dr. Shrok. A good starting point is probably AMS2488 [link is to spec at TechStreet]. Good luck.
finishing.com
Brick, New Jersey
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
