47824
How to remove black coloured corrosion pitting marks on flapper valve steel? [India]
February 12, 2008
We use very thin (less than 0.3 mm) flapper valve steel (20C material) parts for finishing. These parts are immeresed in oil to prevent corrosion. However, we have found heavy corrosion pitting (black coloured spots) on the parts after barrel finishing.
Can you please suggest any chemical or methods by which these pitting marks can be removed?
Sunil Surve
Employee - Mumbai, Maharashtra, India
April 15, 2008
TO REMOVE PITTING, YOU CAN USE SAND BLAST WITH PRESSURE 20 TO 30 PSI OR WET BLAST
Hani Dgaimat
Amman, Jordan
