47077
Brass and aluminium gasket compatibility [South Africa]
November 20, 2007
I want to use a gasket Sealer to seal an aluminium gasket between an aluminium head and cast iron block. the Gasket Sealer contains brass as its active component.
Will this be fine or is there a chance of Galvanic corrosion? Once the gasket is in place likelihood of exposure to moisture is extremely low.
Clinton Palmer
Manufacturer - Johannesburg, South Africa
