finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 47072
Size limitations for anodized parts?
I am designing the roof of a building that will be assembled from shop-fabricated assemblies consisting of a welded aluminum structural frame (6061-T6) which is glazed using Dow silicone sealant. The aluminum must be anodised or powder coated in order to ensure adhesion of the silicone. Presumably the assembly must be anodized or coated after fabrication because the parts will be welded together. Are there size limitations for anodized items? The assembly will be approx. 10 feet long x 4 feet wide x 15 inches deep.
Roger Cumming
Architect - New York, NY
First of three simultaneous responses -- +++++++
There are no size limitations. It's just a matter of finding a shop with large enough tanks. Your parts are not especially large.
- Spartanburg, South Carolina
Second of three simultaneous responses -- +++++++
There are many job shops in New York State with tanks large enough to take the size you posted.
The only limitation is the size of the tanks, rectifier, and chiller that the anodizer has invested in. Lockheed-Georgia had tanks 80 feet long.
For best quality, all welded assemblies should be of the same alloy.
Editor's note:
   Mr. Probert is the
   author of
Third of three simultaneous responses -- +++++++
Roger,
The only limitation is finding someone with an anodising bath large enough to take your parts. You'll just have to ring round your local suppliers and see if anyone has anything large enough. I'm sure you will find someone but it may mean shipping it a few miles (unless you are really lucky and find one on your doorstep).
Brian Terry
