letter 47071
+++++++ Hi Greg,
+++++++ Porcelain coatings, although not actually paint, would be ideal for this. And if the re-bar is red hot they will glow :-) But that's not something you can field apply, you would need to contract with a porcelaining jobshop.
December 23, 2009 I would like to paint rebar, it has been welded and will be outdoors (harsh weather, hot and cold). What kind of paint (applied with brush)? Julie Donald |
Hi, Julie. If this is a D-I-Y project, you will not be pretreating the re-bar by phosphatizing, so most paints will have little power to stop rusting. Therefore, I think you should apply a Zinc Chromate Primer [link is to product info at Amazon] (cold galvanizing compound), as that will put a protective layer of zinc on the rebar to sacrificially protect it, then apply a Rust-oleum type paint in the color of your choice. Good luck.
Ted Mooney finishing.com Brick, New Jersey |
Save
This Page (why?) - Home - privacy policy - ©1995-2010 finishing.com
