HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 47058
Effect of tiodizing on corrosion of Ti 6 Al 4 V
+++++++Does anyone have hard data on the effect of tiodizing (alkaline anodizing) on Ti 6 Al 4 V, such as from a standard corrosion test like ASTM B-117 [link is to spec at TechStreet] ? All I have seen is anecdotal evidence.
Jim Treglio![]() Lakeside, California |
Given your location in California, I know that you're well aware that if you're indeed talking about the actual Tiodize process, your best source of information would be Tiodize themselves located in Huntington Beach, CA. In general titanium itself is highly corrosion resistant and I believe, with or without anodizing, that it would hold up 100's or 1,000's of hours in classic ASTM B117 salt spray testing. The real value of anodic processing of titanium is to (1) impart color used for medical implants, jewlery, bikes, and such and (2) to act as a paint or dry film lubricant base much like a phosphate applied over steel prior to subsequent coating. The AMS2488 [link is to spec at TechStreet] spec for this coating talks about resistance to specific fluids, like solid rocket fuel, as opposed to conventional corrosion resistance which only addresses resistance to chlorides.
Milt Stevenson, Jr. Anoplate Corp Syracuse, New York |
