Ted, huh? :-) Stephen, this work will be environmentally friendly to Canada because the work is being done in China. :-)
Sheldon Taylor |
Thanks Ted,
I agree with your comments, and essence that it's not just the
process that makes it environmentally friendly.
We often see 'environmentally friendly' products from overseas being
shipped half way around the world for consumption.....
However, our company is incrementally moving towards more
eco-friendly solutions....be it from the transportation, packaging
and indeed surface treatment of the products we sell. So if indeed
Powder Coating is a step in the right direction, over clear
anodizing, then that is a step we are considering. If however, it is
environmentally worse, we dont want to go near it!
Can you give me your general opinion on that?
Thanks again,
Stephen
Stephen Lawson
- Vancouver, BC, Canada
Sheldon, even ignoring the environmental consequences of transportation like Chinese freighters hitting bridges and spilling 40,000 gallons of oil into San Francisco Bay, or burning that 40,000 gallons of fuel in the transoceanic voyage, having things manufactured in areas where environmental controls are poor is environmentally hostile. When toxic chemicals are shipped to us from China for babies to suck on, pets to eat, or to be served as seafood, it is not a stretch to say that insufficient attention is paid to environmental consequences in China. There are hundreds of podcasts, YouTube videos, and feature articles in magazines visually documenting this environmental hostility.
Stephen, there are rare instances where it is probably reasonable to say that a finish is not environmentally friendly: cadmium plating for example. But most of the time the analysis would be far beyond our present computational skills. Still, clear anodized parts contain nothing but aluminum and aluminum oxide -- the principal component of the earth's crust; whereas powder coated aluminum parts usually require a chromium based pretreatment, and are shipped with this layer of chromium componds on them between the substrate and the coating. I personally do not think this layer of chromium compounds is a significant environmental issue, but there it is.
Ted Mooney finishing.com Brick, New Jersey |
I would like to add to Ted's comments. The powder industry is now realising that PC is not as environmentally friendly as we all once thought. There is a considerable amount of R & D going on around the world to find an answer to the vast mountains of waste (over-spray) powder being dumped in landfill sites. Some powder applicators try to solidify the waste powder in their ovens but are unable to keep up with the volumes of waste produced. It is a fact that 10 -15% of the powder purchased ends up as waste. I would also agree with Ted that the carbon foot print left due to importing long distances is not only environmentally unfriendly but in the long term will also be economically damaging to the USA and Europe.
Terry Hickling |
So Stephen, what is the presentation to your (potential) customer going to be?
Sheldon Taylor |
Ted, I still get a sense that you feel powder coating is not a
better solution. Let us assume the powder coating is done in the
Canada. I still need to feel comfortable that this is a better
solution than doing the Anodizing. in Canada. I understand that many
shops use Non Chrome based pretreatments, and can dispose of any
prewash very safely.....surely the anodizing acids are considerably
more hazardous to the enviroment. Again, we want to start incremently
improving the products we make, and this seems a logical step, but I
am not hearing that from the comments in this thread. We cannot argue
shipping distances, as that is a variable we have to assume constant
for both finishes.
Stephen
Stephen Lawson
As mentioned, I don't think it's possible to make a strong case either way, Stephen. But we need to make a distinction between chemicals & other materials that are employed during the processing versus chemicals & materials that are shipped out into the environment on the part. As an example, chrome plating employs hazardous chemicals but the plated chrome is safe and it is possible to keep the hazardous chemicals wholely within the factory; in contrast, when one does cadmium plating he puts the hazardous material on the parts and ships the parts out with that material on them.
When one ships clear anodized parts, there is nothing on the parts but aluminum and aluminum oxide whereas powder coated parts will have chrome compounds on them. Chrome-free treatment is not as reliable, as witness the fact that military specifications do not accept it. Considering the cost and waste of corrosion it can hardly be called environmentally friendly to manufacture parts that are inadequately protected from corrosion.
The only chemical employed in anodizing but not in aluminum pretreatment is 10 percent sulfuric acid. So, yes, I think anodizing can be more environmentally than powder coating. But I still think you are requesting that I put a fine point on something that I've already said I can't put a fine point on :-)
"Again, we want to start incremently improving the products we
make, and this seems a logical step, but I am not hearing that from
the comments in this thread".
It seems to me that there is a lot of information in this thread
containing information that you are looking for, it could be that the
new test for the environmentally safe process could be in the way
that the processing and distribution of the product is handled rather
than the actual steps and chemicals used in the process(not
discounting continual R&D). Chemicals are never going away, but
the way the chemicals are handled and disposed of can improve.
Environmental responsibility could be as easy as searching out the
countries that have the most up-to-date enviro-concience and keeping
them on the top of your list of suppliers. There are only so many
countries and each one is blowing it's own horn on environmental
issues because that it's the current rage. Surely your customer must
understand that. Other than that nobody has any magic dust, we're all
locked into using the most current technology.
Sheldon Taylor |
Gentlemen,
PPG industries have just published a white paper looking at the
environmental, economical and performance advantages associated with
the application of liquid and powder coatings on architectural
aluminium. Quite specific, I know, but it gives a feel for the
enviromental advantages of powder coating over wet paint. It does not
mention anodizing though. Makes an interesting read, have a
look.
Hope this helps
Drew
http://corporateportal.ppg.com/NA/IdeaScapes/samples/download/
Drew Devlin
- North Lincolnshire
Thanks, Drew. I found the "Architectural Applications for Liquid and Powder Fluoropolymer Coatings: An Objective Review" very informative.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
