47045
Discolouration of Olive Passivation
Dears,
I am doing the zinc plating with all pasivations. Recently I am facing the disclouration of olive passivation only. This problem starts after a day or two. Pls. suggest the possible reasons and solution on the problem.
Santosh Pawar
Plating shop employee - Maharashtra, India
Hello.
First clear that what u meant by discolouration.
Well in my view if u r maintaining the chloride content too high it might lead to deposition of the olive green pass. to little bit slower.
Also for good results heat the pass. at about 28--32 degrees c.
After Passivation bake it for 15--20 mins. at about 35--40 degrees c.
Hope it works.
Sean Aarchr
- Chandigarh
List of Directories
