47038
PROTECTING 1075 SPRING STEEL
I require a finish on a part that will prevent it from rusting. We
start with a flat piece of 1075 spring steel in its annealed state.
The part is cut to size and a set of holes are added. We then bent
the piece into a "U" shape; it is then hardened to approximately to
RC 45. This is the point at which I am unsure of how to proceed.
Could anyone recommend black oxide, phosphate, or something else
entirely? The final appearance of the part is not extremely critical
as it will be hidden during operation.
Kevin Groen
Product designer - Belleville, Ontario, Canada
If it's permissable for the part to be oily, I'd probably go with
the phosphating. If not, you might investigate autophoretic coating.
Good luck. Other readers may have additional suggestions.
finishing.com
Brick, New Jersey
