47026
Hard chrome plating with no strike? why?
What is the technical reason that most hard chrome plating specs,
i.e. AMS-2406 [link is to spec at TechStreet], call out
specifically to chrome plate directly on basis metal with no strike?
Why would it be preferred to not strike when applying a nickel strike
under hard chrome increases the corrosion resistance and life of the
part? Yes, the engineering spec can specify a nickel strike but I
want to know why the default specifically says no strike. There must
be a reason or they wouldn't have mentioned it in the spec at
all.
I want to decrease the corrosion/pitting occuring on the base metal
under the chrome but don't want to sacrifice any of the beneficial
properties of the coating such as wear resistance and hardness or the
adhesion.
Art Caples
plating shop employee - Oklahoma City, Oklahoma
I wasn't involved in writing the spec and can't claim to know the
reason, Art. But my suspicion is that is has to do with adhesion.
Hard chrome plating can exhibit "perfect adhesion" (impossible to
separate the plating at the interface even with a carefully designed
pull test like the Ollard test). Perfect adhesion seems unlikely in
multi-layer plating. I would encourage someone who actually knows the
answer to override my guess :-)
finishing.com
Brick, New Jersey
Mostly iron parts will slightly etch in the chrome solution
(giving very good adhesion) while you wait for the part to at least
partially warm up before plating. Some platers will use a very slow
ramp up of amps to allow the part to warm up. The coefficient of
thermal expansion of chrome and iron is enough to cause problems if
you do not.There are some high nickel alloy parts that have to be
Woods nickel struck to get good adhesion.
