47017
Chemical to remove burn marks from
stainless steel? [Pennsylvania]
November 10, 2007
I work for a tanker company my name is Bill, and want to know what
I can use to remove the burn marks from welding I need to find a
chemical to use it must look like it was not touched .
My boss is having me use a flapper wheel but I know that there is
something that I can wipe it off with please if you can help thanks
William Knoche
welder - Lemoyne, PA, USA
November 26, 2007
William:
Typical weld paste for pickling of welds will remove the heat
effected discoloration (heat tint) that you see. It is generally a
blend of nitric and hydrofluoric acid in a gelled solution. After
removal of the heat tint, passivation should be performed with eithor
nitric or citric acid gel passivation. These solutions can be
purchased from a number of suppliers or contact me for
assistance.
