HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 47006
Antiquing copper accents on cedar coffee table without affecting cedar
Hi All, Hobbyist - Kagel Canyon, California, USA
First of two simultaneous responses -- +++++++ I am probably missing something here, but antique the copper and the nails before they are inlayed and after the first coat of varthane and then add the second and third coats of varthane. Note that the varthane will yellow in sunlight and with time. James Watts- Navarre, Florida
Second of two simultaneous responses -- +++++++ Hi Kevin,
I don't want to pretreat the copper because I feel with all the hammering of the nails it will ruin the finish. One option I guess is to apply a brown/black patina after the copper has been inlaid and do it carefully, or possible use a black wax to achieve the effect. Don't want to varathane the copper either as it will show somewhat yellowish and chip off over time. The Shark solution should get me around that problem, so its just a matter of the best way to antique the copper once inlaid on the wood. Any more ideas would be appreciated, I will try and attach a sample pic to show what I am trying to duplicate.
Kevin, your on the right path about applying a patina after installation of the parts. We can set you up with the right patina which can apply with a q-tip or sponge to get the effect you want. Best
Barry Feinman Restore It Yourself, Inc Carlsbad, California |
