46086
Corrosive effect of abc fire extingisher
on aluminum [Florida]
August 2, 2007
I had an accidental discharge of a ABC fire extinisher inside my
Custom Coach. It was pulled through all of the ac return air and
supply ducts. It has been allowed to sit in humid Florida weather.
The hinges on all of the doors are rusted. Can it be cleaned and if
so with what method? Also it permeatted throught the fabric headliner
and all the furniture, as well as the led electrical panel, and the
other appliances. Please help me find the right data to show that the
material cannot be cleaned and what the corrosion factor is on
aluminum.
Roger A. Beale, Sr.
marine & casualty - Jacksonville, Florida
August 9, 2007
The first step would be to get an MSDS from the manufacturer of
the fire extinguisher. These dry chemical extinguishers (I assume
that's what it is) appear to use similar but not exactly identical
mixes of ammonium and phosphate compounds. A quick web search
revealed at least some apocryphal accounts of mild corrosivity
towards metals which might be borne out if time is spent on it. I
didn't immediately see anything justifying your concern that fabrics
and furniture become uncleanable though. Good luck with the
resolution, but I would certainly hope that a discharge of a fire
extinguisher doesn't render a motor home a total loss!
finishing.com
Brick, NJ
