service or an electropolishing process? --> Banner at right cycles thru suppliers) |
Jeffrey Holmes,
CEF |
I am of the opinion that 200 and 300 series stainless steels will polish very well using conventional sulphuric/ phosphoric acid mixes. However, 400 series stainlesses will present a problem due to the risk of included carbides. If you want to electropolish 400 series, you should ask your supplier for specialist solutions.
Trevor Crichton |
You can electropolish everything in one electrolyte to mirror finish, however you need to switch to acid-free electrolyte.
see picture attached of 430 stainless steel before and after electropolishing.
Anna Berkovich |
I'd like to try electropolishing 316 stainless steel. What concentrations of Sulphuric and phosporic acids are typically used? Should there be any other additives? I currently do anodizing and am setting up a separate stainless steel tank to try the electropolishing in. Thank You in advance, John B.
John Best
- State College, PA, USA
75% by volume of 85% phosphoric + 25% by volume 66 Be' sulfuric, no water. Heavy buss and current density 50-100 asf. Temp 80-100F. Use ventilation.
Jeffrey Holmes,
CEF |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
