46032
Hardening a "brush hog" mower blade to
retain its strength and edge
I find that tough grass dulls the blades of my brush hog rather
quickly. I have to pull them off quite often and put an edge back on
them. They are approx 18" long with a thickness of 1/2" with a
leading sharp edge. This application is on a farm tractor not your
reqular garden mower.
Jim Roberts
Shady Springs Farm - Gilmer, Texas
Depending on the type of steel that the blade is made of, you may
consider cryogenic treatment to extend the useful life of the blade.
Cryogenic treatment of carbon steels has been shown to extend the
operational life of cutting tools by as much as two to three times.
After cryogenic treatment, the wear resistance of the steel is
increased, therby enhancing the tool's ability to retain a sharp
edge. Deep cryogenic treatment, or cold treating, is similiar to heat
treating in that Time and Temperature produce Transformations in the
steel. These include the formation of a uniform grain (or crystal)
structure that eliminates voids and imperfections (of retained
austenite) by creating a pure, homogenous crystal structue (of
martensite). Additionally, the carbon structure is modified through
the formation (or precipatation) of eta-carbides. Lastly, residual
stresses, that propigate into cracks, are greatly reduced to
eliminate many failures typically attributed as fatique failures. I
recommend that you give it try. Not only will the blades stay sharper
longer, but because of the reduced sharpening required, they will
have a longer fuctional life. The cost of cryogenic treatment usually
is low enough to provide a fast payabck, especially when you look at
eliminating the down time and associated expense of re-sharpening,
plus extended life of the tool.
