46000
Hard anodizing of extrusions gives
necessary chem resistance, but will cast aluminum?
[Canada]
August 2, 2007
We have a few products that have DI water and/or wet hydrogen
running through them that are either 6061 or 6063 aluminum. We hard
anodize to MIL-A-8625, Type III, Class 1 to prevent both corrosion of
the aluminum parts but more importantly to prevent the aluminum and
its alloys from leaching into the DI water or wet hydrogen as
contaminants.
We are planning to move to a cast aluminum manifold but I haven't
been able to find much on anodizing cast aluminums. I have heard that
Aluminum A356 is anodize-able but don't know how well and if there
are any other grades that are.
Any assistance would be appreciated.
Avi Feinberg
Manufacturing Engineer - Richmond, BC Canada
August 4, 2007
Anodized appearance of A356 is gray due to many Si inclusions and
is rated 4 on a scale of 1 (best) to 5 (worst). Corrosion resistance
is rated 2, very good.
Aluminum casting alloys rated excellent for both anodized appearance
and corrosion resistance include the Al-Mg alloys 514.2, A514.2,
518.2, 520.2, 535.2 ['Almag 35'] and the Al-Zn alloy C712.1. From
Casting Kaiser Aluminum, 3rd Edn. (1973); some alloy designations
have since changed a bit.
>From the Annual Book of ASTM Standards, vol. 02.02 (2001):
ASTM B26/B26M, 'Standard Specification for Aluminum-Alloy Sand
Castings,' lists 514.0, 520.0 & 535.0 as excellent for anodizing
and corrosion resistance.
ASTM B85, 'Standard Specification for Aluminum-Alloy Die Castings,'
lists 518.0 as excellent for anodizing and corrosion
resistance.
ASTM B108, 'Standard Specification for Aluminum-Alloy Permanent Mold
Castings,' lists 513.0 and 535.0 as excellent for anodizing and
corrosion resistance. Alloys 705.0, 707.0, 711.0 and 713.0 are
excellent for anodizing and very good for corrosion resistance.
Note: the alloys best for anodizing and corrosion resistance are
rather poor in castability.
Ken Vlach
- Goleta, California
August 13, 2007
Thanks for the response. In your 1 (best) to 5(worst) scale what
is the criteria? I don't care about appearance at all. The purpose of
anodizing is purely to protect the DI water that will be flowing
through the manifold from pulling contaminating ions from the cast
metal.
Avi Feinberg
- Vancouver, BC, Canada
August 15, 2007
The
Surface Finishing and Treatment of Aluminum and Its Alloys, 6th
Edn., page 432, gives a chart with additional anodizing
characteristics for BS 1490 cast alloys. Ratings are E (excellent),
VG (very good), G (good), M (moderate), U (unsuitable). No cast alloy
is rated E in any category.
Alloy LM25 (~356A) is rated G for protective anodizing, M* for dyed
appearance, U for bright anodizing. *dark colors only.
Alloy LM5 (~514.0), is rated VG, VG and G.
The only other casting alloys in this table having VG ratings for
protective anodizing are 99.5% Al and LM10 (~520.0), both probably
less popular with the foundries than LM5 (514.0). Also, LM10 must be
fairly homogeneous for good anodizing; a bit difficult with 10%
Mg!
Anodize appearance correlates fairly well with corrosion protective.
The anodizing on A356 is dark due to many Si inclusions which disrupt
the continuity and hence protective value of the anodizing. Use
another alloy such as 514.0.
Ken Vlach
August 21, 2007
Ken,
Thank you for your responses. Much appreciated.
Avi Feinberg
