45093
Test for ethanoic acid
[UK]
May 10, 2007
Hello :)
I am an AS Chemistry Student, and Have a planning exercise. I have to
identify 6 liquids. I've almost completed the exercise but have
become stuck! Ahh!
I've been looking for a positive test for ETHANOIC Acid. My original
plan was to add a sample of Iron (3) chloride to all liquids, and
identify by colour change! But I cannot find a suitible equation to
show this!
Does anyone know of the reaction between ethanoic acis and Iorn (3)
Chloride, or of a another postive test for Ethanoic acid?!
Thanks for your times, guys!
Natalie John
A- Level Chemistry Student - Swansea, Wales, UK
May 15, 2007
The easiest method is smell - ethanoic acid (known as acetic acid
in the USA) has a characteristic sharp vinegar smell.
The Yahoo answer re ferric chloride as indicator may be wrong: The
method works for the salts of the acid, but the color disappears in
the acidic solution itself.
If you have access to an IR spectrophotometer, acetic acid has a
well-known spectrum. The C=O bond gives an absorption peak at
1680-1750 cm(-1) and the O-H bond gives a broad trough in the range
2500-3300 cm(-1).
http://www.chemguide.co.uk/analysis/ir/interpret.html
Reaction of acetic acid with an alcohol will produce an ester
(typically, sweet smelling). E.g., reaction with ethyl alcohol (with
sulfuric acid present as catalyst and a desiccant to remove water
produced) produces ethyl acetate, which is commonly found in nail
polish remover and has a fruity smell.
As a weak acid, its solution conductivity is lower & pH is higher
than a strong acid of equal concentration. Titration with 1 N NaOH
solution should produce a characteristic curve (pH vs. volume
titrant).
Reaction with Mg metal will produce H2 gas, and reaction with baking
soda will give CO2 gas [true for most acids]. Wikipedia gives many
properties which may be useful.
http://en.wikipedia.org/wiki/Acetic_acid#Detection
Ken Vlach
- Goleta, California
