45088
Hardened Steel vs. Electroless Nickel
Coated or Anodized Titanium and Galvanic Corrosion
Hello,
We have a titanium machine part which used to be electroless nickel
plated, but due to the application process being environmentally
nightmarish, we've gone to anodize. The part has a bearing housing
which is contacted by the outer race of a tapered roller bearing,
made of hardened steel. The bearing does not see the typical daily
cycling through, such as wheels turning constantly, but think of it
more or less as being used to "dial in" a setting on occasion. Hmmm,
I hope I'm clear on this description...
We knew that the electroless nickel plating showed no signs of
galling or galvanic type of corrosion while it was still being used.
However, we've allowed the vendors to switch to anodize in the
meantime; but we're not sure if anodize will "pass the test of
time".
What are the major differences between nickel and anodize? (besides
cost...)
Does anyone have any suggestions? I think I read in another post
where someone was powder-coating over anodized aluminum. Does this
provide a durable hard shell over the anodoze? Cost? Benefits? Can
the thickness of anodize be controlled? ie. is thicker necessarily
more protective or harder?
Thanks for any input.
Edward J. Yuhas, Jr.
Mechanical Engineer - Picatinny Arsenal, NJ
