45087
Conductive finish for steel standoff
I have an application where I am using a steel male/male standoff
to attach a battery cable (presumably tin plated) to a power block
module on an electric scooter. I am looking for an inexpensive,
electrically conductive, corrosion resistant finish for this
standoff. Since this is similar to an automotive application, and
located inside a chassis compartment of the scooter, I think that I
need a salt spray protection of ~120 hours. I called out a Ford S-437
finish, and a plater had problems with it due to their tumbling
process messing up the threads. They are going to rack plate them on
this batch, but are not going to take any further orders. These parts
are ~1.5" long, and 10mm and 9/16" hex stock. Our volumes are only
5000 pieces a month right now. Any help with this problem would be
greatly appreciated.
John Blaney
Product Designer - Rohnert Park, CA, USA
Dear Mr Blaney,
You could use zinc plating or tin plating both would serve your
purpose. However if you need to rack-plate them, you will have to
find someone willing to do this for you whichever metal you decide to
plate finally.
Khozema
Vahanwala
Saify Ind
Bangalore, Karnataka, India
