45085
Scale Problems on Steel
We need to remove weld scale and glass from steel parts that have
a particularly bad looking weld. Our normal treatment uses 2 mins in
a 20% Sulfuric(Cathodic) to help remove the scale prior to plating
with Nickel. We have tried the following without much success: Longer
immersion times in the 20% Sulfuric, Alkaline Permangante Solution
@100g/L at 120 degrees F, and media blasting. Media Blasting works
everytime but we are not set up to run this kind of volume I am
looking for other alternatives.
J. Ott
plating shop - Hbg, PA
First of two simultaneous responses -- +++++++
Try pickle paste (brush-on) from a welding supplier.
Alkaline permanganate scale conditioning is usually performed at
higher temperatures, 160 to 180°F (71 to 82°C).
Ken Vlach
- Goleta, California
Second of two simultaneous responses -- +++++++
Gentleman,
If usage of Cyanide is not restricted,you can try using the following
composition in Periodic reverse current cleaning,10 seconds forward
and 20 seconds reverse for a period of 15 mts.
Sodium Cyanide 60 gram/litre and Sodium Hydroxide 60
gram/litre.
Temperature shall be ambient.
SHANKARANARAYANAN N
- Bengalooru, Karnataka, India
