45084
Testing Hardcoat with a Conductivity
Tester
I have a tool (6061 Al)that was welded (2139, machined, and then
anodized (hard coat). The appearance looks like an alligator skin
with a montage of green and silver marks. Can you test with a
conductivity tester to see if the hardcoat is present?
Mike Rule
Engineer - St Louis, MO, USA
hardcoat conductivity can be tested by ohmmeter with two metal
contacts. Set the scale limit to 1 kohm, slightly touch the surface
with two contacts in the distance 1-2 sm from each other. If ohmmeter
reading shows more than 1 kohm, that it is good anodizing. However
thickness of the coating can be tested only in metallographic
laboratory with special equipment.
