45082
Why does part become too brittle after the de-embrittlement process? What should I do? [Australia]
May 4, 2007
I work in the automotive industry and having problem with part (Zinc plated and gone thru the de-embrittlement process. During assembly of this part, the tang on the part is too brittle and broken off during the assembly process.Please advise.
Raymond Goh
Quality Engineer - Melbourne, Australia
May 10, 2007
Hydrogen embrittlement damage occurs quickly and is permanent, Raymond. You must do the baking almost immediately -- how much time actually elapsed?
finishing.com
Brick, New Jersey
May 11, 2007
What Ted said is extremely true.
Next, is the part properly designed?? Try mounting a couple dozen unplated parts and see how many break.
Next, you may need to do a pre-bake or a shot peening process.
But normally, if the parts are in the oven within 30 minutes and spend 4 hours with the parts at 375F, you should have no problem. Spending too long in the acid etch is another common cause.
- FL
