45058
Plating Stainless Steel
WE WANT TO ELECTROPLATE ( BRASS / COPPER / NICKEL) ON STAILESS
STEEL 202 GRADE. WE HAVE ACTIVATED IT BUT PEELING SEVERE. PLEASE
SUGGEST US THE CORRECT PROCESS.
DEVASISH
PRODUCT DESIGNER - KANPUR, U.P, INDIA
You may have attempted to activate it, but it doesn't sound to me
like you were actually successful, Devasish. Did you do Wood's
nickel, or what activation procedure did you do? Thanks.
finishing.com
Brick, New Jersey
Thanks Mr. Ted Mooney for you support. The jobs are degreased and
pickled in 10% HCL ( C.P) but it is turning Black , then we tried
with 5% Concentration and it is O.K. We have Plated it with Wood's
Strike Bath. 10% HCL and 140-200Gms/ltr Nickle Chloride was used.
Almost 80% of the Job is still turning Patchy Matt black. Current was
kept at 20- 30ASF. The peeling has reduced but not stopped. But the
dull black patches on the Job in the Wood's bath is not fully covered
in the subsequent plating.
DEVASISH
- Kanpur, U.P, INDIA
First of three simultaneous responses -- +++++++
10% HCL for pickling never enough.
John Hu
Second of three simultaneous responses -- +++++++
You should not have those black patches after the Woods. It should
be a light nickel color with a slight brown cast. It sounds like your
Woods has a metallic contamination. You have to dummy it at vry low
current density overnight. A carbon treatment might also be
necessary.
Guillermo Marrufo
Monterrey, NL, Mexico
Third of three simultaneous responses -- +++++++
hai!
I saw your mail.please do to woods nickel plating propermanner. if
you want to plate s.s. material.material should be mild etched by
plating bath.so you first apply 1/3 of plating current in reverse.
then you apply direct current, do plating.peeloff never happen.
P.KARTHIKEYAN
- Bangalore, India.
