45034
Peel off issue on TO263 nickel leadframes
[Philippines]
May 8, 2007
We are now having problem on this package, peel-off is always
present despite of all pretreatment chemical are in good working
condition no changes in process from die attach upto plating. we need
first to microetch the leadframe prior processing to solder plating
to eliminate this defect. whats the best way to determine the
rootcause of this defect. why do its needed to etch first the
leadframe, when previously its not included in the process.
please help.
Kathy Chua
plating technician - Philippines
May 10, 2007
Microetch retains the original smoothness of the metal. Using a
high power objective microscope, you will see that there are too many
rough edges and spikes on the surface. These roughness can cause poor
plating deposit, such as peeling off. If microetching alone solved
your problem, then you can start from there. There could be changes
that were made on your bare metal, be it on its process or on its raw
material. Ask your vendor.
Franz Cantillano
- Philippines
May 17, 2007
Nickel requires a good activation prior to plating. If you are
encountering peel off problem, it is due to poor activation of
Nickel. Nickel Phosphorous is even more difficult to activate. Check
your leadframe supplier if the material is Ni or NiP. Consult some
chemical suppliers on a good nickel activator.
Germie Maravilla
- Laguna, Philippines
