45008
Nickel Plating Cracking at Weld Joints,
Steel [New York]
May 2, 2007
We are a furniture manufacturer using a new plater that offers
black nickel plating. We recently had a problem with some of the
joints of our welded steel (1018) frames cracking at the joint. These
items were copper plated prior to nickel plating, and the cracking
appears to be only in the nickel-copper layer and grinding away the
affected area indicated that the welds were still intact underneath.
We had several parts done in this fashion, and only one of the pieces
exhibited this problem.
David Scott
Product manufacturer - New York, NY, USA
First of two simultaneous responses -- May 3, 2007
It's only a guess, but I'll bet there was a hairline crack in the
weld, small enough that it was smeared over by grinding.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
Second of two simultaneous responses -- May 3, 2007
Hello David,
Because this was just one part that failed, I would suspect the welds
were not properly sand or bead blasted (whichever process the new
plater uses). Just a basic soak and electroclean are not enough to
clean welds prior to plating.
Mark Baker
Process Engineer - Syracuse, NY, USA
