45001
Hard coating for cryogenic aluminum gear
May 3, 2007
Hello,My name is Rick, I work as a mechanical designer/machinist
in a University Physics Department. I am making 15" diameter aluminum
gears for use in a cryogenic enviornment (vacuum and 4 degrees
Kelvin). I would like some coating options to improve the strength
and wear of the teeth. Something that will not outgass or flake off
in use.
Teeth are 24 DP, 360 teeth,1/8" thickness. This will be a low torque,
low rpm application.
Your assistance in this matter will be much appreciated. Thank you.
Rick Bihary
Research University Designer - Cleveland, Ohio, USA
May 8, 2007
I can think of two options at least for "normal temp ranges", but
must confess I know little about operation at such low temperatures.
One is hard anodizing. The other one would be electroless nickel
plating either hardened or as plated.
Guillermo Marrufo
Monterrey, NL, Mexico
May 9, 2007
4 Kelvin is incredibly cold. I think that the differences in the
coefficients of thermal expansion is too great for hard anodize to
work. I will question if EN will work for the same reason, especially
in a vacuum. I think that you will probably have to go with titanium
or stainless steel to work in that environment.
I would cold cycle it a couple of times before I used it as it very
well might warp. Some things can be cryogenically hardened.
