44087
Epoxy floor coating
[India]
February 21, 2007
We are manufactruing epoxy floor coating systems using 100%
solvent free Bisphenol A and cycloaliphatic amine curing agent. I
have some peculiar problems faced at various site and the problems
are inconsistent in nature even though the formulation is same.
We used a 22000 CPS epoxy resin with curing agent and made a seal
coat to cover porosity in epoxy screed mortar base. The first seal
coat filled up in the gaps and was very strong and hard. It achieved
full curing ( touch dry) in 3 hours. Later when we put the same
material on top we found that it started delaminating after 7
days.
I understand that this could be because of early curing of sealer .
Pls advise
Raju
Epoxy floor mfg - Pune, Maharashtra, India
First of two simultaneous responses -- February 21, 2007
How old was the concrete. Did you acid etch and rinse well and dry
well?
- FL
Second of two simultaneous responses -- February 22, 2007
Yes, this is normal, although the curing seems too rapid. For
molecular bonding between coats, the second coat must be applied
before the first coat has fully hardened. The first coat is typically
dry to the touch but thumbnail dentable (perhaps even slightly tacky
as '100% solids' have no solvent to evaporate). If the first coat has
cured hard, it must be sanded or abrasive blasted to allow some
mechanical adhesion.
Each epoxy has a recoating 'window' (minimum & maximum time
interval) which decreases as temperature increases. A typical
formulation might allow recoating between 8 and 48 hours from initial
coating. As the manufacturer, you must determine proper recoating
times at various temperatures for your customers.
Ken Vlach
- Goleta, California
