44069
What is zinc ash and bottom dross loss?
What is the normal ratio of the Zinc ash and bottom dross compared
with the consumed Zinc in hot dip galvanization and how I can recover
pure Zinc from the ash and dross effectively. I am a manager and
producing galvanized wire by hot dip process and the Zinc lost
through dross and ash is really bothering me much.So far I remelted
the ash (big sizes) in a curicible and recovered metallic Zinc.I have
also used ammonium chloride but not found very effective.How can I
increase the effectiveness.Is there other additives to mix with the
ash and dross?
If you could give me some recommentation it will be very appreciated.
Süleyman
BEÞLÝ
ÖZYAÞAR A.Þ - Silivri-ISTANBUL, TURKEY
Could you please answer how I can reduce the smoke(fume) created
during hot dip galvanization on the Zinc furnace and reduce the zinc
ratio retained in the ash?
Süleyman
BEÞLÝ
--ISTANBUL, TURKEY
