44025
Chrome in nickel bath
Our company produces galvanic nickel deposition.
In our nickel bath we have nickelsulfate, nickelchloride and boric
acid.
Did the concentration of 10mg/l chrome reduce the cathode
efficiency?
Which other problems can we have with chrome in nickel bath?
When yes, how can we remove this chrome (with methods and chemicals)
to have no problems with the normal deposition of nickel?
Claudius Vergeiner
- Langkampfen, Tirol, Austria
A very small addition of sodium thiosulfate will reduce the chrome
to trivalent and it will cause no problems thereafter.
Jeffrey Holmes,
CEF
- Spartanburg, SC, USA
A small amount of sodium thiosulafte will work,as Jeff has stated
but if you don't want to go the checmical route you could filter it
with a fresh filter & a good carbon pack or another way to go is
with an ion exchange unit,that will take nickel out of chrome as
well,but it is not meant to be run for long periods because
eventually will start takeing the chrome out of your bath.
Best Regards,
Brian C. Gaylets
- Scranton, Pennsylvania, U.S.A.
