43095
Electroless Nickel plating Versus Nickel
Electroplating - Corrosion and Wear Resistance
[Minnesota]
November 20, 2006
Hello,
I work in the fluid controls business where a lot of electroless
nickel is used for corrosion and wear protection. One of our
providers of nickel plating has asked if we would consider the
electroplating process versus the electroless nickel plating process.
By switching to electroplated nickel, will we obtain the same or
better corrosion and wear resistance properties as electroless
nickel?
Craig Matthew Geyer
Water Controls - Sartell, Minnesota
November 22, 2006
Most surely you will obtain less corrosion resistance (only under
very peculiar situations is electronickel more resistant than
electroless nickel), also more wear (electronickel is softer). But
above all, you´ll get non-uniform coverage or thickness which in
turn may affect your tight tolerances after plating or leave exposed
areas.
Guillermo Marrufo
Monterrey, NL, Mexico
