43060
How to improve surface finish on a
machined aluminum/steel part [Michigan]
November 15, 2006
Hello all,
My name is Andrew Germain and I am a student/co-op mechanical
engineer who attends Kettering University, formerly General Motors
Institute of Technology. I have been given the task of finding ways
to improve surface finish on a machined aluminum or steel part.
However, the guidelines are that the improvement comes from within
the machining processes we use, and therefore additions of a grinding
operation, or the addition of any other operation is less than
ideal.
My question is this, is there anyway to improve surface finish by
changing the machines cutting head speed, depth of cut, or any other
parameter? I have found on the Internet that the addition of a
coolant to a preexisting operation can be beneficial, but have not
found significant sources to back up this claim.
Thank you all for your help, and thanks to everyone who's response to
other topics has already proven beneficial.
Andrew Gregory Germain
Co-op engineer/student - Montague, Michigan, U.S.A.
November 20, 2006
Optimal machining parameters depend upon the particular alloy and
heat treatment condition. Your school may already have a machining
database with tool geometry, speed, depth of roughing and final cuts,
etc. Appropriate cutting fluids can improve machining finish by
removing heat and acting as lubricant. This also improves
productivity and tooling life. See
Machinery's Handbook or
Metals Handbook Vol. 16 Machining (1989). A
Machining Data Handbook (3rd edn., 2 vols., 1980)
was published by the DoD-funded Machinability Data Center (Metcut
Research in Cincinnati). Much info significantly pre-dates the
Internet, e.g.,
Machining Aluminum Alloys (Reynolds Metals Co.,
1952),
Machining Kaiser Aluminum (1955), or
Aluminum Vol. III, Fabrication and Finishing
(1967). There are also newer, basic and advanced CNC Machining
books.
The National Center for Manufacturing Sciences (http://www.ncms.org)
may be of help (GM is a partner). A recent project 'DEVELOPMENT AND
EVALUATION OF NEAR-DRY MACHINE TOOLS FOR THE PRODUCTION OF ALUMINUM
COMPONENTS' may be of interest.
Suppliers of machining fluids, such as
Chemetall Oakite,
Henkel,
MacDermid, etc., may have
product bulletins and other info.
Ken Vlach
- Goleta, California
