HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 43059
Corrosion prevention on mild steel
Hello sir,
I m a student and working on plasma assisted chemical vapour deposition.My project involves teflon like coating on mild steel during that I have encountered problem of corrosion.This is done by pyrolising Teflon scrape.Can u suggest me any method for corrosion prevention on mild steel.
Waiting eagerly for ur reply.
student - Ahmedabad, Gujarat, India
Dear neha
will you please explain in detail.
what is the cleaning process you have followed for that. how much is the coating thickness you are offering .is corrision formed before or after coating .
let me hear clearly.so that I may help you .
best regards,
angadala, PVD coatings engineer
- Pune, Maharastra, India
