43039
White rust
I'm the manager in tube producing mill in Slovenia. The company
name is Alpos. We are a producer of tubes made from hot rolled
strip.Our production range is from 15 x 15 x 1,5 till 120 x 120 x 5
ane runded tubes as well.
The problem that we are facing with is that we recently started
producing tubes made from pregalvanized cold rolled strip. We are
using same lubricant for all types of production.After processing the
tubes were packed as usual. After a fery short period of time white
rust appeared. My question is how to avoid these situation, maybe
using some special lubricant for both, or something else.
I'll be very grateful for any help.
Vlado Krebs
Alpos - Slovenia
White rust on galvanized surfaces is common where the galv is
stored in moist conditions.
Passivation (Cr or similar) is often the best prevention, but is only
a temporary fix.
In your case of using pregalvanized strip to form tube we must assume
you mean an ERW tube mill? (You didn't say).
Its harder to passivate an older galv surface than one freshly
galvanized. You could specify your strip to be passivated before you
buy?
If you are using ERW tubemill, then surely the joint will be
ungalvanized and then unprotected from corrosion? This strip of
ungalvanized steel (which will be inside and outside), will surely
corrode with time. In this case, what is the point of using
pre-galvanized strip?
Geoff Crowley
galvanizing &
powder coating shop
Glasgow, Scotland
Dear Mr.Crowley
Thanks for Your ansver. I have to explain more. The weld is outside
metalized with zinc wire heated and sprayed.
Problem is that tubes runes on the packing machine litle bit wet, and
white rust occurs all over the tube.
Vlado Krebs
- Velenje, Slovenia
You now say that the tube is zinc metal sprayed. This is not
galvanized steel then. Sprayed zinc does not have a metallurgical
bond to the steel, rather it has a mechanical bond. It has the
advantage that it can be applied in different sites, but the
disadvantage that it can fall off, and is porous, and of uneven
thickness.
White rust can form on both zinc spray and galvanized though, and
passivation is one possible way to prevent this. Otherwise you must
keep your tubes dry, or prevent them from touching each other.
Geoff Crowley
galvanizing &
powder coating shop
Glasgow, Scotland
You might be able to passivate the corrosion process by packaging
with packaging materials treated with VCI (volatile corrosion
inhibitors). The tubes would have to be free of corrosion prior to
packing them of course. Your situation outlines a common challenge
for shipped (especially export) of metals (including galvanized).
Scott Kotvis
- Alsip, IL, USA
