43010
Electrolysis With Metal Toilet Tank
Components
The situation is corroding stainless steel chain which connects
the flapper valve to the metal or anodized trip lever arm in the
toilet tank. The tank to bowl bolts that fasten the tank to the bowl
are steel, and the trip lever arm I believe is anodized aluminum. The
chain, eyelet that connects the chain, and the "S" Hook which
connects to the trip lever arm are all stainless steel. The confusing
thing is that the corrosion is only occuring on the portion of the
chain that is in the water, not the portion out of the water. All
this is happening in only three week. The chain ends up coming apart,
and you can not flush the toilet.
Bruce Antunez
Plumbing Components - Pomona, CA, USA
Bogus stainless steel. Try some nitric acid or
Lime-A-Way [link is to product info at Amazon] on it. If it
fizzes, it's not stainless -- maybe zinc or aluminum or magnesium???
Ken Vlach
- Goleta, California
