HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 43006
Use of titanium as anode
For plating inside a bore of length approx. 10' , can titanium anode be used?
Ramesh Vaidelectroplaters - India
First of four simultaneous responses -- ++++++
Hi Ramesh.
In certain cases,Yes.But make sure bare anode(auxillary) does not touch on the sides of the tube(cathode)which may cause short circute.U may mask it with cloth.
But please be specific about your bath and what u are doing to get a specific answer from an open foroum like this!
Regards.
T.K. Mohan plating process supplier Mumbai, India |
Second of four simultaneous responses -- ++++++
What plated metal, chemistry, cycle and base metal?
Third of four simultaneous responses -- ++++++
It will work in some and not in others. What are you plating?
James Watts- Navarre, Florida
Fourth of four simultaneous responses -- ++++++
Hello Ramesh,
What type of plating are you doing? In most cases Ti can be used as an anode for primary or auxillary applications. Good Luck!
Process Engineer - Syracuse, New York
