Letter 42077
Black spots on zinc plating with
trivalent (clear) chromate [Ohio]
August 30, 2006
Has anyone seen black spots on zinc plating with trivalent
(clear)chromates? We recently converted from hexavalent to trivalent
and began seeing what appeared to be a white haze that turns into
very small black spot. We use a sealant (silicate) over the chromate.
Gary Clyburn
Captive shope plating fittings - Dayton, Ohio, USA
August 31, 2006
Is your zinc bath Alkaline or Acid Chloride? Rack or Barrel?
Giving more details would narrow things down a bit.
JEFF W LENTZ
Plating Co. - Lancaster, PA
September 3, 2006
Gary
There is a wide set of probabilities , which may or may not
help.
However..
If perhaps you are a cyanide zinc fan, the black spots are entrapped
cyanide in porosities , bleeding out post passivate and
drying...
If you are an alk Zinc fan, Try beefing up your Post Plate Nitric
acid dip to ensure no caustic carry over into the Trivalent
passivate.
And if you happen to be an acid zinc fan , using a barrel here are 2
probabilities.
One: Your Current is too High and causes imprints of the barrel holes
on the parts which is burning due to inability of solution to carry
current. Check Zinc and Total chloride to data sheet levels. Reduce
current.
Two. If you run rack, it might be loose zinc particles co depositing
and then corroding faster than the regular surface.
In alk zinc Rack too, such a possibility exists.
Now Tell us what you do..?
Rack or barrel, Cyanide acid or alk ??
Gary,
One more possibility existe..
Are you applying the Topcoat while the part is wet, or do you dry
first , then Topcoat ?
If the second possibility is being followed, the parts will behave as
described by you..
Check.
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
