Letter 42047
How do you use hydrochloric acid to clean
brick paving without doing damage to bricks and garden
I want to clean a large area of brick paving and was told to use
hydrocloric acid, the label has fallen off bottle and I need to know
how much to mix with water to use it safely to the bricks, garden and
any pets around?
Jean Leach
householder - Perth , Western Australia
This is a hazardous material and should not be applied on a whim
or unless you know exactly why you're doing it. It is NOT a cleaner
and is not for cleaning brick; it is a destroyer of concrete and
mortar and the reason it is used is to dissolve mortar stains from
brick. If you have no label you don't know the starting
concentration, Jean, so any talk of dilution ratio is meaningless.
Take the bottle to a hazardous wate disposal facility, and buy a
fresh one if you insist on using hydrochloric acid -- it's
inexpensive stuff, but will kill your plants and certainly burn your
pets if they are exposed to it. Good luck!
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
