HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 42030
Regeneration cycle: switching from HCl to H2SO4
Dear Sir/Madam,
I would like to consult on this area which I have no knowledge on it.
Currently my supplier is switching the from using HCl to H2SO4 for the Regeneration cycle.
The supplier also claim to check on all the equipment parts and do checks on it. But they are unable to provide datas on the sulfate level and other parameters until they have implement the change.
However my company did not measure the sulfate level on the in-coming material. Hence it is also hard to compare the after change sulfate level.
I am not sure whether this change will affect the in-coming material sulfate which in return might affect our company's end product performance.
Hence would you mind to give some feedback on whether is there any difference between HCl or H2SO4 for the Regeneration cycle? Do you have any experience on this type of change before.
Please help by providing your expertise in the case.
electronics manufacturing - Singapore
Not enough information to even guess at an answer.
What is being regenerated? Maybe, ion exchange resin?
What is the product and what specifications must it meet?
Ken Vlach - Goleta, California |
