(Cycles thru suppliers)
Letter 42012
Require rust prevention on black oxide part [India]
August 25, 2006
We are exporter of steel forged and machined product to our US customers. We are presently stuggling with a rust problem on one of our component. We are presently manufacturing a wood cutter it is basically a forged component which is then machined, heat treated and finally teeth grinding is carried out. This is then sent for Black Oxide, now since it is a cutter so our basic requirement is adhesion (i.e. blackening remains even after cutting operation) after blackening WD-40 is applied for rust prevention. Finally before packing the product its teeths are coated with wax. Now we are facing the problem here that our product starts rusting in the wax coated area (Wax coated area comprise of a cavity which is non-machined forging part and grinded tooth). Rusting problem is basically encountered in the forged cavity. So we require some suggestion on this to prevent our parts from rust. Then other thing which we observed was that as the WD-40 has lower flash point it gets evapourated while wax coating , so we are also looking for some rust preventive with higher flash point somwhere 160-200 degree celcius.
RANJAN SHARMA
- NOIDA, U.P., INDIA
September 1, 2006
The WD-40 and hot-melt wax are not the most appropriate materials for this purpose.
The black oxiding process should include dipping in a water-displacing rust preventative that dries to a thin, dry-touch film. The black oxide chemical suppliers have such products. Don't know whether the US companies -- Electrochemical Products Inc., Heatbath Corporation, John Schneider and Associates Inc., Luster-On Products -- distribute in India, but the Indian company Guardian Anti-Corrosives Private Limited surely does.
Ken Vlach
- Goleta, California
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
