Letter 42007
Can I paint a walk-in cooler?
I own a couple of pizza restaurants called Papa Joe's Pizza and
would like to paint the aluminum walk-in cooler the colors of the
high school next door. I actually messed up the walls of the cooler
by thinking they were stainless steel and used oven
cleaner--ouch--black mess! The school colors idea is just a cover up
(no pun intended)! So I really need some help. No bad weather
conditions to worry about.
Mama Joe
Papa Joe's Pizza - Dripping Springs, Texas
Can you? None of us can answer that. May you, you do not need our
permission. Should you, probably. How to-Go to a real paint store and
get a primer made for aluminum. Wash the cooler with an abrasive pad
(not steel wool) with a little TSP
[Trisodium Phosphate [link is to product info at Amazon]] from
a wallpaper store. Rinse, dry, prime and paint. Make sure that the
primer and the paint are compatible. Spray is optimal. If you roll,
use a short nap roller.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
