![]() (Cycles thru suppliers) |
Letter 42000
Stainless is a better product than chrome plated steel in your application. Your friends are not very educated in automobile restoration. Nickle chrome over steel is generally about .0015" thick (1/2 the diameter of a human hair.)
Stainless will not rust and is easily cleaned. Steel that is chrome plated can rust, pit and the plating can start to peel. Once it starts to peel you may as well throw it away because stripping the plating is not EPA friendly and there are not many shops that will do it anymore.
If you did purchase stainless you got the better product.
T.J. Luniewski
- MPLS, MN, USA
Thanks for the input, T.J., although I don't really agree with you. While it is possible to get low quality chrome plating, good quality chrome plating lasts decades in the most adverse situations without any rusting or pitting, and certainly no peeling, as we see on OEM auto trim. Conversely, when OEMs put stainless trim on an automobile, they plate it with a flash of chrome to deter rust and pitting.
And the finest stainless steel polishing will not favorably compare to "show" chrome or Harley chrome in appearance.
Ted Mooney finishing.com Brick, New Jersey |
Ted, you said: "good quality chrome plating lasts decades in the
no peeling, as we see on OEM auto trim."
Not so fast. My '96 Caddy has four trim pieces, each about 1/2" X 4'
which started blistering and peeling in less than a year from new. I
contacted GM's Cadillac divisioin, and their response was, in effect,
"Tough luck. We have no interest in replacing those parts."
Jeffrey Holmes,
CEF |
Don't get me started on GM not standing behind their products, Jeffrey. My personal experience is that no matter how many thousands of dollars you spend to repeatedly replace the same misdesigned component, they will do nothing, and the purpose of their "investigation team" is only to stall for years in hopes you'll junk or sell the lemon :-)
Even those of us who steadfastly refused to buy Japanese for decades are eventually forced to concede that you can't build great cars with the GM mindset :-)
Still in many cases, if not most, today's chrome plated parts do indeed last decades.
In Ben's application I still believe SST would be better and hold
up much better. I am assuming the panels Ben mentions are covers for
the bottom of the doors, rockers and quarters etc. These are areas
that see above normal abuse with normal driving let alone if he takes
it off road. Chips/scratches in chrome plating will allow the base
metal to rust, chips in SST will never rust. My point is that with
the same maintenence, stainless steel will hold up better to the
elements than chrome plated products in Ben's application. It may not
have the same deep shine chrome has but can be buffed to a very nice
finish.
Anyways.... Ben, The quickest way to tell is to place a magnet on the
panel(before installation) If it doesn't stick it is SST (unless it
is 400 series or 17-4 but that's a whole nother lesson)
T.J. Luniewski
- MPLS, MN
Well, that's 2 to 1 in favor of stainless, Ben.
Nothing looks as bright and beautiful as a good chrome plated
finish.
However stainless steel side panels and rocker mouldings will
tolerate attack from road debris much better than chrome.
Chrome needs to be cleaned and waxed just like a fine paint job.
Don't get chrome if you don't plan on pampering it.
The auto manufacturers balance cost and quality. Unfortunately cost
wins over quality sometimes. After ten years it would be hard to find
a piece of chrome plated pot metal that has not shown signs of
deterioration.
Frank DeGuire |
Yet none of you gave any photos to look at? How about you prove your knowledge
D, Macleod
- Boston, Ma
Please send us a nice picture of a mirror, D. -- not the frame, just the reflective area -- and then we'll post a picture of a chrome plated surface. You won't know, however, whether we actually posted a picture of chrome plating or we just used your picture of the mirror, because they will look exactly the same -- you don't see the chrome, only whatever is reflected in it :-)
It is notoriously difficult to photograph a bright reflective surface. What is usually done is you photograph a reflection of a screen or a test pattern to look for any distortion or dull areas. But it can't be that hard for you to find a Harley and see high quality chrome plating firsthand.
Please try to be careful with future postings because, without the benefit of voice inflections, your entry sounds snotty and demanding -- and you may not like what the Harley rider does if you take that tone with him :-)
Was planning on making a back rest for a VTX1800 out of stainless. As heat will be used in fabrication was interested in your suggestion as to removing heat stains in stainless. Is a better option having it flash chromed instead of endless polishing?
Alan Heim
welder/fabicator
Greensboro, No. Carolina
Save
This Page (why?) - Home - ©1995-2009 finishing.com
