Letter 41097
Dissolving aluminum in internal passages of
carbide drill bits
Does anyone have experience with dissolving aluminum that has
plugged the passages of coolant thru solid carbide drills. The
passages are .020 diameter and the plug withstands 1000psi.
Bob Willi
Mfg. Eng. - Peoria, IL, USA
1 cup of red devil lye to a gal of water. Can be warmed to about
140F for faster action. Higher temp generates a caustic steam. I
would use a pyrex glass container. Periodically remove and rinse. It
may not be a fast process, but it is equipment safe. Use face mask,
safety shield and rubber
protective gloves [link is to product info at Amazon].
Alternatively, diluted 50% muriatic acid can also be used without
appreciable harm to carbide. More obnoxious but faster.
Guillermo Marrufo
Monterrey, NL, Mexico
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a
new question or inquiry on a
different subject.
