HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 41081
Transferring 1200 degree fah. on a conveyor belt
What material can I use to hold parts that are at a temperature of 1200 degrees fah. The parts have to be conveyed to cool off with a water spray.
Chester StumpMetal Edge - Milwaukee, Wisconsin
OK, I give up. What are you doing this for?
James Watts- Navarre, Florida
I used to extrude aluminum onto a run-out and transfer table made of solid graphite block. The al. was almost 1000* when it hit the table, I'm sure it would withstand 1200*. I don't know what the industry uses now.
Sheldon Taylor supply chain electronics Wake Forest, North Carolina |
Yours is a matter of a simple heat transfer analysis. Since we don't have the details you'll have to figure out the final design. How much mass of hot aluminum is invloved versus how much mass (thickness) you can have in your table. How much time elapses between each run to let the table cool down. Any steel can withstand that temperature for a short time, but I would consider stainless steel to avoid rust since there is water involved. Thickness of the SS to provide necessary stiffness would depend on the above factors.
Check out heat treat furnace belts. Try searching on the internet, there are several companies that make furnace belts...
Kevin W. Gallich- Freemansburg, Pennsylvania, USA
