Letter 41079 Etching titanium [Florida]June 9, 2006 We are making very small titanium parts for the consumer industry.
We are investment casting various titanium and zirconium alloys. We
want to try etching with concentrations of pure Nitric and water
rather than mess with Hydroflouric. Scott Jackson
First of two simultaneous responses -- June 13, 2006 I can surely be wrong, but I doubt if any concentration of nitric will etch Ti. You do not have to use HF acid which is nasty!It does go froom being an 800 pound tiger to a wild pussy cat with lowering %. The safer option is to replace the HF acid with ammonium bi flouride which is a white crystal. The resulting nitric- ammonium bi flouride solution is not much worse than the nitric alone. It does require proper training and safety equipment. You should also talk to your local hospital or emergency services so they can carry the correct burn materials. If they look at you like an idiot, tell them to look up the treatment for HF acid burns. James Watts
Second of two simultaneous responses -- June 13, 2006 Try a mixture of 5% sodium hydroxide and 5% hydrogen peroxide for etching titanium. It is a fairly slow process, requiring possibly an hour or longer, depending on how deep you need to etch.
Dear Reader: please choose what you want to do--
Save
